pkunk said:I use a 150-3 & a 150-5, both with the standard pad that they came with. I'm mostly sanding stuff that comes out of my Woodmaster38 & some in the house stuff after an install. Should I have a different set of pads & why. Thanks
Michael Kellough said:Hey Bob I noticed the web site says the 150-3 comes with the soft pad. It didn't say which the 150-5 comes with. Do you have that info?
Neil Clemmons said:Bob
I can find the replacement hard pad for the Rotex on your site. What is the right hard pad part number for the 150/3?
Neil
John Langevin said:Bob,
While we're on the subject of Sander Pads, could you enlighten us as to the proper use of:
1. The Interface Pad - is this required for porper performance with the 400 grit and higher abrasives? Does it affect (either way) dust collection?
2. The various Sponge Pads for use in Paint Removal/Preparation operations - I tried a Yellow Smooth pad in my RO150EX with no result, then I noticed on the product card it showed what looked like plastic bottles of Polishing Compounds?
Thanks for the info. Does Festool market Rubbing or Polishing Compounds in the U.S.? As I said they were shown on the sponge product card but do not appear in the catalog.
Lou Miller said:I bought the hard pad and have used it on my rotex. It seems to make a substantial difference in how aggressive it makes the sander. Wears out the paper a bit faster though.
I also bought one of the "long-life" pads and used it on my ETS150/3. Let's just say I won't be doing that ever again, there wasn't anything long-life about it. It was worthless in about two or three weeks. I recently bought a standard pad (same as the one the came with the sander). I've already used it as much, if not more, as the long-life pad, and all is well.
I'm on my 3rd pad replacement and think that at the price they charge for these things they ought to last a little longer. I'm not pushing these sanders hard, and before long the disks start flying off. ??? I'm familiar with how velcro works as a Woodmaster owner and I need to sand at a reasonable cost. Ad the replacement pads to a box of paper and it's getting expensive.Lou Miller said:Its just a pad for the sanders. Supposed to be for heavy use, but I didn't think so.
http://www.bobmarinosbesttools.com/product_detail.html?sid=cb2f1a47b161e1e1976e132e0d4a29b8&pid=491935
Eiji F said:The hook and loop things on the pads wear out faster when you put pressure down on the sander. Pressing down on the sander during operation may remove stock faster but creates more heat than the the pad can withstand premature h&l failure is the result.
I find that if I let the sander do the work I get better results on the work piece and my arms and sanding pads last longer. ;D
Thanks.
