junk731
- Sep 10, 2008
QuailRider43 said:Well, I ended up with a Mirka sanding block and a Festool ETS EC 150 3 mm. I'm a bit scared of the ETS for my thin oil-varnish blend finish coats however, so I may just end up lightly hand sanding.
Its good that your scared you should be, but time and a few screw ups with power sanding and you will understand better why some of us that do this all the time recommend hand sanding with high grit foam backed paper.
John
