Sanding Disk Storage
mhmcgrath
Here’s a pic of a little project to store 150mm disks. Dowels and piece of 3:4 plywood to hold down disks. Labels on those ply pieces make rearranging easy. Bolts attach to alum rail at end of Dashboard bench. What do you think?
For me it would be too exposed. To much dust, dirt, humidity and sunlight on the discs. Also hard to take with you. Hence I have them in a Systainer.
But if you go through them at a much higher rate in the same workshop; nice!
But you have a bunch with older hole pattern, so I wonder about your volume  [tongue]
Thx for your observations. Shop is climate controlled and limited sunlight. I also have the Systainer storage for remote use. Some grits less used - old inventory - still work fine for me when needed. Just needed a simple, quick access at my workspace. Looking for ideas on the “net” sheets I’m starting to use. Especially, for delta sheets and the inline (rectangle) sheets.
There was just enough room behind my chop station platform for a shelf to accommodate 5” discs in their original cartons.  I have sanding discs from 40 grit to 600 grit organized in sequence.
The top discs in each carton accumulate saw dust, but that cannot be harmful for a sanding disc.  By the time they are installed, most of the dust has fallen off.  I marked the cartons with bold markers as to the grit number.
It does require I walk about 10 feet from where I usually do my sanding operations, but the unused space is now used.  I’m pleased with it.
I buy my discs from Amazon in boxes of 100 discs.  Very economical, but the 100 discs last a long time.
I cut the lids off of the cartons for easier access.
I keep a small vertical rack for dispensing a few discs at a time on my back bench. The bulk of the stock I keep is stored in the original boxes. They fit behind the Systainers on the pull-out. When the cubbies get low, I pull out a few more.
This is an old pic with no-hole paper for my pneumatic sander. I don't use it much anymore, so the shelves go refilled with the 9 hole variety. I labeled them with a Dymo machine too.
I don't have to be mobile, so that's not a concern, at least now. That may change at some point, then a Systainer will likely be the way to go.
