Sanding sealer and Lacquer.
Lbob131
Can  sanding sealer  be used  as a  base  for  2 pack  acid catylising  lacquer?
Many Thanks.
The product data sheet should include a recommended sanding sealer. I'd recommend that you stick with products from the same manufacturer to reduce the possibility of products being incompatible.
You should never use catalyzed product over non catalyzed. You can go the other way though.
