tjbnwi
- May 12, 2008
Seeing as the nails are painted, my guess is that stringer has been like that longer than some/most here have been alive.
If you're really worried about it drive a few Ledger Loks through the header into the stringer.
Remember, as/if/when you raise the stringer back into contact with the lower edge of the header, the tread now moves away from the header. Something else to deal with. The riser may also prevent you from raising the stringer without removing it.
