[member=44099]Cheese[/member]
Yeah I definitely went old school ;D I don’t have a PC so things like Sketch Up are unavailable to me on my iPad.
And I agree 100% on the wax. I used Minwax paste wax to coat the pieces. Special dark paste wax on the sapele and natural paste wax on the maple.
[member=71257]WillB[/member]
You’re welcome!
And you’re absolutely right about the width needing to be spot on. If anything you need your drawer to be more on the narrower side width wise so you can shim it out for a perfect fit. That’s exactly what I ended up doing. This is the shim set I got. It’s a little spendy but worked great.https://www.amazon.com/gp/aw/d/B007UQ74VA?psc=1&ref=ppx_pop_mob_b_asin_title
I honestly don’t foresee too many problems with the slides even with expansion and contraction. The drawer and slides won’t expand much in width. They will expand a bit in height but I left maybe 0.015” to 0.020” clearance between the mating dovetails height wise. So the drawers should stay tight side to side keeping the motion smooth and if they expand in height there is wiggle room to keep them running smooth as well. Of course only time will tell
Thanks again for the kind words!
[member=60777]Bugsysiegals[/member]
So I had the Incra LS Positioner attached to my MFT/3 at the time and used it with my CMS-VL with a custom setup I made. The fence was actually not Incra. It was the Jessem TA fence and I used the Mite-R-Slide II to cut the dovetails. I have since sold that setup and I am in between tables. I will be ordering the Incra table in the near future.
Thanks! Yeah I was a little worried about scratching them too but I don’t think I need to worry. I coated them with Minwax polyurethane followed by paste wax so I hope they hold up!
You’re welcome!
