Save $40 on GRS-16, GRE-13, and Systainer Bundle at TSO
TSO_Products
Retailer
Save $40 on our Fall Bundle, which includes the GRS-16 PE v2 Guide Rail Square, GRE-13 Guide Rail Extension, Systainer3 and Custom Kaizen Foam Insert! This bundle savings is good through Tuesday, October 24. No coupon code needed; simply add all four products to your cart and the $40 savings is applied automatically.
[size=24pt]What's Included?
GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
GRE-13 Guide Rail Extension with GRC-12 Connectors
The GRE-13 guide rail extension provides the right support at both ends of the cut, and its convenient length fits in a Systainer! Comes with a set of our renowned GRC-12 auto-aligning guide rail connectors.
Kaizen Foam Insert for GRS-16, GRE-13, and GRC-12
This two-layer custom Kaizen Foam insert protects your GRS-16, GRE-13, and GRC-12 connectors in a single Systainer!
TSO Products Systainer3 M 112
Keep your kit organized and protected with our TSO branded blue Systainer3, size M 112. This systainer toolbox is made of durable, robust, high-quality ABS for long service-life. All Systainers share an identical footprint for easy stacking, storing, and transport.
Shop the TSO Fall Bundle
What else is new at TSO?
JUST RELEASED! GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
