4ncar said:
Ha! yes fellers, hose connected, but I could see that happening to the likes of me! lol Off the top of my head, not sure of the tooth count(tool @ home, me @ work!), but it is the provided blade with the saw. Vac on full, running on auto. I briefly checked the bag, and short of taking it out didn't look full, but as mentioned TONS of suction at the end of the hose. Which then brings us to material and how I was cutting... solid core Pine door blank ripping down 1/16-1/18" swaths 80"... NO underlayment. Set the door on my MFT3 with door overhanging, clamped, set my guiderails(2 joined) and ripped away! I was cutting some smaller stock last night(set up traditionally) on the MFT3, and noticed that the sawdust was shooting out in front of the blade...
You've only fenced 1/3 of the yard and wondering why the dogs get out [wink]
The vac hose is connected to the back of the saw housing so it's only going to capture the dust that's channeled into the saw housing.
Most times you're cutting a panel down and the panel itself "fences" the dust in so 2/3's of it goes up into the saw housing.
Unless you have something under the panel about 1/3 of the dust will escape out the bottom of the kerf. Use sacrificial underlayment to capture that third.
When you're trimming the edge you're going to loose most of the dust because the "fence" is down.
The simplest solution is to put another board of similar thickness next to the edge you're trimming.
Another solution is to tape a piece of cardboard to the saw housing so that it hangs down, especially along the front of the saw.
Once you get most of the "fences" replaced you'll see exactly where the remaining dust gets out and how to stop it.
When you think you've got it all buttoned down you'll find you've captured nearly all the dust right up until the blade exits the wood at the end.
You can capture that too by putting a sacrificial block at the end.
That piece has to be renewed for each cut but it's easily done with masking tape.
