DeformedTree
- May 19, 2018
JimH2 said:I will add that the fact that the SawStop destroys your blade is meaningless because you still have your hand, all fingers and only need a band aid. If it does trigger and you have to buy a new brake and blade you will not care. The plus to it is you are forced to stand down until you can replace them, which you need to do when you have avoided a life altering injury. The weak point of the Bosch is that you can fire it right back up and keep cutting, which is a terrible plan.
But, the other way around is if you have just one saw/blade, if you destroy the saw/blade you won't be able to finish the job, but if you loose a hand, you still have another hand and a functioning saw, so you will be able to work thru and get the job done. If you have saw stop, you may have both hands, but you have no saw and can't complete the job. Do you want to risk upsetting the customer or being late on a job?
