Sawing your own Lumber
Wood_Slice
I have a 17" Grizzly band saw and wanted to saw some logs into useable lumber. I can probably safely saw a 16" diameter x 3-4 feet length of a log with a little jig-rigging on my band saw for support and squaring. My actual question is lets say I would like the final dried rough dimension of the wood to be 4/4 or 6/4 or 8/4 and so on----> How much extra thickness do I need to add to counteract the drying shrinkage of the wood. Does it shrink? If yes, by how much? 1/16",1/8", 1/4" etc. Different wood species different shrinkage rates.
I sawed some 14" diameter x 2 foot logs already and the width was honestly just spit balling whatever looked OK to my eye while trying to cut out the heartwood.
Your problem is not shrinkage but warping as every wood will warp a bit while drying. Even restrained one.
The warping reserve so you can plane/joint it later is way bigger compared to the shrinkage reserve you may need.
1/4 on each side for softwood is a safe bet, less if you have a way to restrain the wood well while drying or it is some quality hardwood which warps less
