Tom the Remodeler
If you have an oscillating spindle sander, have you considered producing an offset template and producing the piece that way? You'd certainly avoid the problem of going "uphill" with a router bit....
woodferret said:The 1/4 micro bits are for light feed engagement only. You only get less (far less) than 1/8 feed surface. Any more and it'll kick or break.
Packard said:It turns out that they eliminated the overhead “Amazon” sign. They had a labyrinth leading to something called “returns”. No indication that it was for Amazon returns. Through the labyrinth I find the booth with a Amazon sign beneath the counter top. It is not visible from the aisle.
Tom Gensmer said:I'm certain this is on purpose, and, in Kohl's mind, more of a "feature" than a "bug", in the same way that grocery stores place the essentials (milk, eggs, etc....) in the back of the store, forcing you to walk by everything else, hoping that you'll buy more than you planned..... I wouldn't be surprised if they (Kohls) eventually placed the return kiosk on wheels so they can strategically move it around the store so people returning items are constantly exploring parts of the store they wouldn't otherwise visit.
Tom Gensmer said:Packard said:It turns out that they eliminated the overhead “Amazon” sign. They had a labyrinth leading to something called “returns”. No indication that it was for Amazon returns. Through the labyrinth I find the booth with a Amazon sign beneath the counter top. It is not visible from the aisle.
Packard said:I turns out that my purchase was from Peachtree, a pretty good vendor, plying its goods through Amazon.com.
I am wondering if it would matter to the QC people at Whiteside to know about this.
Hahahaha!PaulMarcel said:Tom Gensmer said:I'm certain this is on purpose, and, in Kohl's mind, more of a "feature" than a "bug", in the same way that grocery stores place the essentials (milk, eggs, etc....) in the back of the store, forcing you to walk by everything else, hoping that you'll buy more than you planned..... I wouldn't be surprised if they (Kohls) eventually placed the return kiosk on wheels so they can strategically move it around the store so people returning items are constantly exploring parts of the store they wouldn't otherwise visit.
ha! I'm picturing a return desk mounted atop of 4 Roombas that drift semi-randomly around the store...
Packard said:I designed the items so that I don’t need tight radii. So a half inch bit works fine. I’m going to switch to maple to see what the difference it makes.
A note about the bees wax finish. It felt a bit slippery after I applied it, and buffing did not seem to improve that. But when left overnight the feel is smooth and slick. Very nice. I’m thinking I should not have tried to buff all the wax off. It probably would have been absorbed into the wood.
Crazyraceguy said:As the others have said, you need to be cutting "down-hill" with the grain. What you have there is akin to rubbing a cat backwards.
Packard said:I discovered last night that I have a never-used pattern router bit, with a ball bearing guided tip. It still had on the waxy, rubbery protective coating (officially, CAB or cellulose acetate butyrate), so old, but never used.
It is a 3/8”, a with non-helical, two bladed cutter.
This cutter is very grabby in grain climbing situations. Far more grabby that the 1/2” diameter pattern bit that I have with 3 straight cutters.
Is it the smaller diameter or the fact that there are only two cutters that makes this bit more aggressive in grain climbing situations?
Peter Halle said:Packard said:I discovered last night that I have a never-used pattern router bit, with a ball bearing guided tip. It still had on the waxy, rubbery protective coating (officially, CAB or cellulose acetate butyrate), so old, but never used.
I watched something within the past month or so that explained that pattern routing with a larger diameter bit will reduce the likelihood of tarot due to the exit angle of the cutters. This would also seem to make the larger cutters less likely be grabby as you described in my mind.
Packard said:The router bit has been sent back to Amazon. The photo below shows my very first attempt at using this bit. The surface is smooth, but it leaves a trail of two parallel lines. Those lines appear on all the cuts. Not very deep, but very noticeable and time consuming to sand out.
And this image shows when I tried to route against the grain, which resulted in the mess shown below and a violet kickback.
And here are the near-mortal wounds. [big grin]
And here are the two sides of the template. The heavy magic marker area shows where to use the router.
So I learned here about grain direction and using a router. It was never a problem with maple or oak, but apparently a problem with pine.
So the problem is solved.
Returning the router bit by brining it to Kohls was a real burden. I should have spent the $1.00 and dropped it off at UPS.
Kohls moves the Amazon booth every time I visit to return something. So I end up wandering around the store looking for it.
I arrived around 11:00 a.m., found a handy handicapped parking space and went looking for the Amazon booth. There are rarely any floor personnel at Kohls. I finally asked the (very busy) cashier where the booth was.
So now my bad hip is acting up from all the walking. I’m ticked off at Kohls, and by extension Amazon.
I tried to complain to Amazon. They make that as difficult as possible. They have a “chat” function, but it does not play well with an IPad. The status bar obstructs what you are writing. I complained about that and they arranged a phone call. But the caller was (probably) from India and heavily accented and difficult to understand.
Likewise, he could not follow what I was saying and at the end of my diatribe, I found that I was speaking to a dead line.
The next time I’ll either try Staples or UPS (which has a $1.00 fee attached to it).
The updated spell checker from Apple, auto-corrects words that are not misspelled and changes it. I just typed “or” and it changed it to “of”. Annoying,
