Holmz
- Oct 11, 2014
RussellS said:Pike_101 said:Designed and developed to cut through 2'+ of solid lake ice, it makes incredibly short work of compacted snow and frozen banks. Cuts through a 6' bank in about 10 seconds, and the more icy and compacted the better.
How do you get it into the snow/ice? Its very easy to see how it would cut very easily ONCE the blade is through the ice. But how do you get it through the 2 feet of ice to start with? I see it has a sharp tip. Are you supposed to spin it around in your hand like a top and drill your own starting hole? And for that 6 feet of snow bank, do you shove it REAL hard into the bank and hope it comes out the other side. Or are you supposed to climb on top of the bank and cut from the edge back? The picture you showed is nice. Just like cutting a board laying on the workbench. But hand saws don't work too well if you are in the middle of the room trying to cut a hole into a solid floor. Hard to get started. The tool here seems ideal for perfect conditions. But not useful in every other situation.
Somewhere I have a ˜20" long version I made out of alloy with a rosewood handle back in the 80s.
(I cut igloo blocks with it while camping, and the main issue was the snow sticking to the alloy.)
But I do not recall an issue plunging it in, just like in a vampire movie you shove it in.
Ice could be a challenge, but I think like a jig saw without a drilled hole... One can start out at 0 degrees and pull and lift, and eventually get it to be straight up at 90 degrees.
Another method would be a large auger as the ski race teams use for the gates.
They go in about 18" and a long iron bar can pry out blocks pretty quick with the holes are a foot apart.
