scotch brite
lordinteriors
does anyone in the uk know where i can get scotch brite pads for my rotex 150 mm ive been looking all over the place and they wood be very helpful
lee
I've not tried it on my RO125, but I would think you could just stick a Scotch Brite pad on the hook & loop pad of the RO125 or 150, trim it round with a pair of old scissors and you'd be good to go.
For initial polishing I do just that with a chunk of jute back carpet removed from our living room when the carpeting was replaced.  The piece I kept was just like new, since it was originally along the wall, beneath a large book case.  I wouldn't use it for finish polishing, but for the initial polishing after removing orange peel and such with sand paper (I usually go to 800 grit) with the red heavy duty rubbing compound, it works great and costs almost nothing!
When you install minerrel work surfaces, you use scothbrite pads to polish them. Put cream onto surface and work in with one scotch brite pad. Then polish up with a second dry pad.
Be careful the pad does not come off without you noticing, your pad will get stuffed.
I got mine from mitchells worktops in southampton. They have a web site and are helpful.
I think halfords might sell them or
http://www.3mselect.co.uk/c-251-scotch-brite-cleaning-products.aspx
ah got it
http://www.clickcleaning.co.uk/search.aspx?search=scotch&category=1&gclid=CJuC64rqlKACFZBb4wod0V2Adg
and these are round !! web search scotch brite pads
