Deansocial said:
It's the same for screwing any 2 things together. You need clearance in first bit to stop screw jacking
Not really dude. If you held two pieces of timber together they stay in ''floating'' position so if they where touching they would stay touching if you held them 10mm apart they would stay 10 mm apart cus your driving the screw in at the same rate in both materials of the same.
Even if their was a slight difference your body weight would easily fight against it but if you hit metal your body weight would NOT keep it down it would actually lift you up or damage the screw or it would spin inside the wood creating a kinda clearance hole. All would depend on the wood and screw size etc.
JMB
