Screwdriver deals
I have gone off screwdriver sets these days, a 1/4 hex drive handle and a handful of bits does everything and a special bits set with all the odd stuff gets the job done.
I actually had a look at that last night as I have several not quite complete sets, but for us in OZ it's around $340 all up sadly.
Pretty cool, but I just bought the Wera set, with the mounting bracket Between that and the Festool set, I'm well covered.
Yes, handle style, material, and actual fit to your hand, is important to me with screwdrivers. Nothing worse than a handle you dislike in a Screwdriver.... except maybe hating the bit end... [embarassed] [sad]
Michael Kellough said:
The Wera handle is my favorite but it’s bulky so I don’t want a whole lot of them. I use this one. It comes with 6 bits and the handle socket is empty so I add my own square bit and then the set is good for nearly any task.
Yes, agreed 100%, it is very inconvenient (and space wasting) to have dedicated "fixed" handle style screwdrivers for every tip type and size. But, they do feel better, perform better, and don't end-up magnetized.
Most (not all) of the removable tip drivers have magnetic retainers, some have the wire-clip (or both).
All of that adds bulk to the tip, which may cause clearance problems.
I have several sets of the 1" tips, for a lots of different shapes, just for the "fit anything". (hex, Torx, Pozi, etc)
They are not ideal though, just handy. For the same reason that I keep different formats of hex drivers, I just like having certain drivers in a dedicated fixed shank.
The Festool Centro-tech set is pretty close. They have 100mm shanks and I use a Wera handle.
I do the basically the same thing with power drivers too, impact or CXS. I'm just not a fan of magnetic tips, since I use a lot of #2 Robertson (square). They stick in the fasteners so well, that the tip often pulls out and stays with the screw. I know there are holders/adapters that are not magnetic, with better retention, but they are even bulkier.
morts10n said:
I would never own a set of screwdrivers that all have identical colored handles
The Wera are not, well not really. They are grouped by tip type, the handles sized by tip size.
The green are Philips, Red Robertson, and white Pozi-driv
The bigger handles are #2, smaller #1.
I don't have a #1 square in this format, but it's fairly rare in my world, enough that I don't mind getting it out of deeper storage anyway.
The old-school Craftsman always had the same red/blue/clear, and you have to go out of your way to get different colored handles with the automotive brands. Their sets are all matching too. You would have to buy them individually to get that.
Companies like Klein (and I'm sure others) have the tip size/shape printed on the end of the handles, so they can be identified inside a toolbelt/pouch.
Until I got this set, I have used deliberately mis-matched drivers. They sit in tray in the top drawer. Irwin for #2 Robertson, Grass for Pozi, and a cheap Philips from the big box store. There was a matching slotted driver there too, but it grew feet and walked away. That was the motivation for the Weras......even though I already have the Festool set. It doesn't make a whole lot of sense economically, but they sure are handy.
The somewhat matchiness and mounting system were big factors, though I could have achieved similar results with a magnet and the drivers I already had  [blink] not near as cool looking though.
My metric drivers are like that.
  As noted by others, Mechanics/ Technician sets are almost always same handles for all style screwdrivers-
I've never found it a problem with screwdrivers laid out in a toolbox drawer, but if stored vertically like in a can or container if space is tight,, I can see where that would suck.... [big grin]
The Wera Kraftform drivers and many other brands are coded on the handle side and a large graphic on the top with the the type and size.
If you can see the top, you can tell what the tip is with a quick glance.
[attachimg=2]
Ron
Ron
Yes, and the newest ( a few years now) generation of Wera have large color code circles on the end in place of the small gold / silver printing. With the size in large color coded number in the center of the circle.
Wera Take It Easy
I added some different coloured shrink wrap to my 1/4 hex driver bits to quickly show the Phillips from the Pozi drive.
