Sent back my Pro 5 after 2 days use. Hard to control and terrible surface finish. My RO90 is easier to control and gives a better finish. Looks like I will have to wait at least 2 more weeks to get a sander that works. That will make almost 7 months from time of order. I have seen post from others that had their sanders repaired to their satisfaction. Hope I fair as well.
The other issue that is not repairable is the new dust collection connector. It drops about a tsp dust every time you disconnect it and that is a problem when sanding lead paints. The festool system has been certified for sanding lead paints and is one of the reasons I bought it. This new connector may be an issue with certification. I will have to get into a habit of leaving the sander/vacuum running when disconnecting a nd pull hose off slowly.
