Shaker Table
lewisc
I wanted to share a few pictures from a Shaker Hall Table built using Dominos and Festool Sander/Extractor. I'm following plans from Christian Becksvoort with the exception of the joinery.
I keep being impressed by the quality of sander and how easy the dominos to cut and install. I've used the dominos for the top which has given me near perfect alignment. After turning the legs, it was easy to mark and cut the domino holes. A bit of shaping and sanding and it's near ready to glue up.
Nice work. Are you shapping the curves with the sander too, or are you using a router for that?
Thanks. I used a jigsaw for the curves on the ends, touch them up on the linisher and still have a bit of work to do by hand. I've also done a small rounder over on each edge.
