Cheese said:
SoonerFan said:
[member=44099]Cheese[/member] here are a couple photos of the floor. As [member=167]neilc[/member] pointed out, it's hard to find screws, washers, etc. that are dropped with this color. I had this color at my old house and liked it so stuck with it this time around. I use a magnetic roller if needed.
Thanks for that [member=28223]SoonerFan[/member] that looks great, [thumbs up] I was especially curious about the intersection of the floor and the base, it looks like you just rolled it over both items.
Now for the questions... [big grin]
1. Did you apply this yourself?
2. Is there any sagging on the vertical base surfaces?
3. Was there any special floor prep that was needed?
4. I assume it was new cement, how long did it have to cure before it could be epoxied?
5. Do you ever pull a car into the garage?
6. Is the floor slippery when wet?
[member=44099]Cheese[/member] here you go:
1. Did you apply this yourself? No. I had it professionally installed.
2. Is there any sagging on the vertical base surfaces? It did my shop, a small shed attached to the back of my shop and the garage. No sagging issues.
3. Was there any special floor prep that was needed? Prep included checking moisture content, removing loose/cracked concrete (only existed on the 30 year old garage floor) and replacing, grinding the surface and filling the expansion joints. After that it was paint, apply flakes, wait 24 hours, and finally apply top coat. Then I needed to wait 72 hours to move in the heavy tools.
4. I assume it was new cement, how long did it have to cure before it could be epoxied? Shop was built in 2020 so I waited about 2.5 years. Some epoxy companies say you need to wait 6 months. The company that did my concrete work suggested 18 months.
5. Do you ever pull a car into the garage? In the shop we almost never pull in a vehicle. In the garage we back in and out everyday.
6. Is the floor slippery when wet? We did not notice a big difference at our old place. Current shop never gets wet. New garage has not gotten too wet yet but assume it will be able the same as our old place.
Couple other points. (1) I was thinking about just having them apply paint and the top coat. I wanted grey but wanted to be able to find dropped washers, nails, etc. easier. I learned the flakes add lots of protection. The company applied about 360 lbs. of flakes per 1,000 sq. feet (~160 kilos per 93 sq. meters for our metric friends). They mentioned that hardly any paint is showing on my floor. (2) The first time I used epoxy/flake/top coat the top coat of poly did not have UV protection. In that garage/shop I worked with the garage door open lots. The floor did yellow a bit after several years of sun. (3) They did roll on all the paint and used a brush where the floor meets the stem wall. (4) The curing process stinks. I covered the back side of door into the house from the garage with a .7MM plastic tarp and used masking tape to seal the top, bottom and and sides. It helped a bunch.
Also here are a few pictures of the garage. One show the stem wall which is tall than the stem wall in the shop. Another show how the epoxy terminates ant the end of the garage floor. Finally one show the entry into the house. I built new stairs and added bullnose treads to have something nicer than what we had before.
Let me know if you have more questions, would like close up pictures or whatever else I can do to help your planning.
