Shop-made case for Sys-minis
Crazyraceguy
I've been fiddling with this in my spare time (early mornings before work, usually) for a few days.
I had an off-cut of some decent plywood. It's not true BB, but somewhat of a copy.
Since I have always liked the look of the rabbet/tongue and dado, I use it when I can. I do drawer boxes and stuff like that, for myself mostly.
That lends itself to this type of case, pretty well. I just need to add a back, though ultimately, it won't be necessary. Now it sits on my miter saw stand, but eventually will be on a french cleat wall at home. There is won't need a back.
Today, I got out the Origin and made a cut-out in the shelves, as grab spaces. One of the guys in the shop said it looked like a cookie monster bite. I left the top un-cut, to be useable space as a shelf for something else later.
I thought this was going to be quick and easy, since I already have this pattern, from cutting board hand-holds. It didn't work out so well though. There was a pretty big storm last night, which took out the power for a while. There is a fairly sophisticated interrupter unit, that usually handles that easily. A simple re-set makes everything go again. This time, not so much. The dust collection system was not happy, but a call to the service people got that sorted.
The bad part was the server. It didn't want to re-start properly, so no Wi-Fi. Origin was not happy about that, so I drew out the circles from memory, with the on-board tools. It worked, but took some extra fiddling. I also made a template version, so I can repeat it with any router.
Made something similar a few years ago. Cut the finger clearance (not as elaborate as yours) after the photo was taken.
That's really cool. I hadn't thought about a double, even though that's the way the new factory-made ones are designed. Although, they turn them sideways, to stay in the original footprint. I like the forward-facing look better, since it matches the full-sized ones.
I still need to acquire a few more to fill it up. I also just thought about making "feet pockets" in the top. Then I can put another one on top and have it not move around.
I like the idea of a first-aid kit in one, but they are sold out as minis. I guess I could get a red latch and sticker set.
[member=608]Mark Katz[/member] what do you have in the taller one? I have seen those on the Systainer Store site, but don't know what I would put in one. Mine are filled with router bits, wrenches, and other small things for the Shaper Origin.
I know I'm not Mark, but my taller Sys-Minis have GRK boxes or construction screw boxes in them in various sizes.
Some of the others have my pins, brads, and staples, all in their original packaging to keep them from intermingling.
Mine is a standard Mini with a substitute red latch and sticker.
As for the two larger ones, that's a good question. Right now I'm mostly unable to access my workshop to actually look inside (I think I even have labels on them now). I'm pretty sure one has a collection of Rockler Bench Cookies with associated risers and cones. The other, I think, has my Veritas Large Router Plane with a fence and a full set of blades.
I love the Minis. I have several deployed around the workshop besides those in the rack. Haven't found a reason to buy a Micro yet.
The best use of micros that I have seen is DF500 bits.
I may do that someday, since I do have one, but I keep my Domino bits in the case that came with the tenon set. That little box has that live hinge thing though, so it may not last forever. Those always seem to fail.
I'm just getting into minis. I got the first one as part of the Shaper Plate. It holds the accompanying clamps, leveling pins, and such. I bought a second one for the growing collection of router bits. I keep them separate from the regular ones.
I keep a lot of small stuff in the drawers of that big roller chest.
I probably have 15 minis, I have 4 in my van. Three Is my Milwaukee 1/8" rotary, my metric wrenches and allen set and  and 4 IIs, all containing Milwaukee 12v tools.  Bandfile lives in one, inline and right angle die grinders in another and rachet band clamps in one.. The ones in the shop all contain specialized tools, scrapers, my Ulmia spring corner clamps, one @ for imperial or metric nut drivers, Festool sanding blocks and sponge sheets, my parts for my MFS sets etc.
I'll be that guy and point out that, annoyingly, the Sys-Mini sizes are actually I and III, rather than I and II.
Probably something to do with the Sys-Classic and T-LOC Sys III being twice the height of the Sys I, with the Sys II somewhere in between.
[member=58857]Crazyraceguy[/member] does the Shaper have to connect to the ShaperCloud (or what ever it's called) to load files onto the machine or can you transfer them directly from a PC?
There's often things in the tech press about companies shutting down cloud based services and bricking internet connected things.
just curious
Regards
Bob
[member=76043]bobtskutter[/member] Compatible files loaded into your Shaper Files page will automatically be found in the Shaper Origin if it is connected to the internet. If not, you can copy the file onto a usb drive and plug that in to the SO.
It’s worthwhile to first load files into Shaper Studio where at the very least you can designate the depths how the tool should follow paths. Then send the S Studio version on to S Files and when at the tool those designations will already be there.
[member=76043]bobtskutter[/member] it does not have to, but it sure simplifies things. I probably could have used my phone as a WiFi hotspot and transferred it that way. If I had known about the outage, before I left home, I could have used the thumb drive. The thing is, Studio is web-based anyway, so that adds another issue. There again, if I had done it all with the phone, that would have worked too.  Though I don't like the phone version as well as the way it works on my laptop.
It worked out ok, just took a few minutes longer.
Saturday morning I made a foot holding pocket pattern in the top of this unit. It may not have any immediate use, because of where it sits in the shop. Once I get it home and mounted lower, on a cleat wall, that will change. I don't even have enough minis to fill it yet, though I have started moving my hardware around some.
I didn't think of this before I glued it together, so I had to figure out how to get a tape board aligned with the top. Since the back is not on yet, it wasn't too hard.
