Wood_Junkie
- Dec 2, 2009
I know someone will know the answer to this... I can't put hands-on the various parts to do a 'real life test' (no local shops have 'em in stock or know the answer).
I want to attach my shop vac (in the garage) to a non-antistatic 36mm hose. What adapter will work to connect a "standard" shop vac hose/hose connector to a Festool hose?
IIRC shop-vac hose connectors taper from about 2 1/2" to 2 1/4" or so... I would like something that allows quick disconnection and reconnection.
Purposes: Still use shop vac hookup with my bandsaw and for other cleanup. Quick connect to a 36mm hose to use with my TS55 / jigsaw / etc when needed, which would eliminate my need/desire to carry the CT up from the basement all the time.
Here are the candidates:
http://www.festoolusa.com/products/dust-extractors/reducing-hose-sleeves/hose-sleeve-antistatic-connector-sleeve-493047.html
http://www.festoolusa.com/products/dust-extractors/reducing-hose-sleeves/hose-sleeve-nonantistatic-hose-reducer-452897.html
Or do I need something different that's not listed here?
OR, alternatively (and much cheaper) has anyone used this Ridgid hose/adapter kit to connect with Festool hoses / dust ports?
http://www.homedepot.com/Tools-Hardware-Wet-Dry-Vacuums-Accessories/h_d1/N-5yc1vZ1xl5Zb8pd/R-100375877/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
