In hindsight, I wish I had purchased a square sander before I invested so heavily in 3 sanders and paper of the circular and triangle type. (RO150, RO90 for triangle to get corners on refinishing projects, 150/3 for fine work).
A BIG square sander can do 99% of all the needs you should come across.... and means you don't have to switch between circular RO pads and triangle pads (and have to have all that paper for both). Top of that, you can micro flatten much better with the square...like table tops in the field (if you don't have a wide belt platen or can't take the project to one).
Also the square pad gives you option to try any abrasive you want (with the hole punch thingy)...
My 2 cents on sanders...it does depend on what you will be working on most a little...overhead vs. heavy removal (almost always best done with chemicals anyway---unless an external boating project where its illegal to use chems) etc. There are special applications that warrant different sanders...but I'm going to come out and say it....which sander was originally developed for wood in the first place? (hint its not the RO90 nor the 150/3...and it begins with RS).
Sorry Festool, you already got my money though so stand down
Christopher
Christopher
