Hello I need your advice how to build a bookcase with thr following characteristics:
- dimensions: 84"H x 48" W x 11"D
- the final producg will be painted white
- most likely it will end up being full of books, some quite heavy hardcover type
- From my point of view I don't eed a back but I assume it's needed for structure
- I would lime to minimize the vertical elements if possible
- the tools I have: domino, of1400 router, 55req stracksaw with rails, drill, hand planes and solid workbench, 150/3 sander, chiesels, dozuko hand saw, chop saw
I never applied edge band with an iron but if plywood is the only way to go I'll learn. Maybe making a face frame would solve this.
1. Can I use the typical $49 8x4' 3/4" plywood sold by Lowes or should I spring for the $110+ type sold by other stores with better veneer and less voids between plys?
2. Do you have some designs in mind you can share?
3. Should I consider making it of solid wood, maybe 5/4 oak?
4. A friend recommended MDO butI cannot find anywhere around me.
5. Would yoh route dados in the vertical elements or use the domino?
6. How would you finish it, what paint and primer would you use for white?
Thank you,
george
Thank you,
george
