smorgasbord
- Jan 7, 2022
Maybe it's just Peter Millard:=5BLsbZUqiVojWEbC&t=70
But, I've seen other people use them this way too. Millard runs on about how this doesn't work with tops thicker than 18mm unless you chamfer the tops of the holes, and even rails against (pun intended) Makita rail clamps for having a longer arm that makes fitting them into MFT holes even more difficult/impossible.
=70O6rPzb_VNHahlx&t=571
Call me old-fashioned, but this was solved centuries ago with the use of an end vise and bench dogs (ironically enough, the UK company Benchdogs Tools don't make actual traditional bench dogs). When I built my bench 30 years ago, I had read "The Workbench Book" cover to cover a few times. This was way before MFTs and the 96mm spacing standard, but there's a section there about square versus round dog holes with wear being the main reason not to go round. That, of course, is rendered somewhat moot by the use of relatively frequently replaced tops made from MDF, but without that end vise, or at least a horizontal moving dog, you don't get the great surface hold-down that has the additional advantage of not protruding above the work surface, so you can plane/sand that surface in its entirety while held securely.
Some old benches do have round holes for the hammer-in single piece cast iron clamps, which were used where there weren't parallel edges to squeeze between bench dogs.
I'm not an MFT user, but it strikes me as weird that clamps designed to hold track saw rails to a workpiece have been adopted as the main/preferable way to hold workpieces to a workbench, especially when there's no track in sight.
