chrisrosenb
- Sep 1, 2007
When the contractors cap was installed on my truck, they ran small fused power & ground wires from the battery back to the cap for interior lighting. I am now installing air bags on the rear axle. I am installing a small compressor in the cap to operate the air bags.
The compressor also requires fused wiring to be run to the battery for power.
Many times I would have like to have had access to 12 volt outlets at the back of the truck.
Instead of having several wires running from the battery to the back of the truck, I am considering running 2 larger wires.
One fused line for the power & one for the ground. I would then put a ganged fuse block in the cap. The block I have found is rated for a total of 65 amps & has 6 separate fused power connections.
The problem I am having, is the size wire I need to make the run from the battery to the rear. The run is about 25 feet.
I have found several charts online, but they do not agree. Some charts list wire length as total of hot & ground & others just give a length. Wire sizes are all over the place.
I need help.
I need help.
