Richard/RMW
- Jul 11, 2010
Cheese said:Svar said:Wait... So, you are customizing stainless fittings (!) to be used as electrical conduits (!) that leave a garage (!)
You must be retired. [big grin]
BTW, tips for working with Stainless: If same type of stainless is used on both parts, threads will gall and cold weld together and you won't be able to separate them. Pipe threads are especially prone to this due to their cone shape and high friction. Don't ask how I know.
I am retired...there is a God. [big grin]
I always chose a different stainless for both the bolt and the nut. 304 bolts are common and 316 nuts are fairly easy to find so that's the combination I used, to work around that issue. However, that wasn't the cure 100% of the time. Sometimes under high torque conditions, the fasteners still welded themselves together. [sad]
What I've used in the last 8-10 years is a light application of Never-Seez. That works wonders. Just don't get it on yourself as it readily transfers to anything you touch.
And no less than the Nuclear Grade will do for you [not worthy] [big grin]
Well, I guess if a fella needs stainless conduits, why skimp?
RMW
