ear3
- Jul 24, 2014
I just recently got my T18+3, and wanted to post a brief notice on what I see as the superiority of this drill over others.
I was making a plywood base on which to secure my Dewalt planer, and needed to drill some holes through which to pass the 1/4-20 screws I would use to secure the planer to the base. In the past, when I needed to drill a hole like this -- one that was the exact dimensions of the anchor (and I wasn't using a drill press) -- I would always use a drill bit 1/64th narrower. This was to compensate for the wobble/run-out that I just took as a given feature of any drill, be it a Dewalt, a Milwaukee or whatever. So I used the same procedure with the T18, employing a 15/64 drill bit to make the holes. When I tried to insert the screws, the holes were too tight, and so I had to redrill the hole with a 1/4 bit.
The chuck on the T18 is so accurate, that I no longer have to factor the imperfections of the machine into the equation when selecting bits. 1/4" = 1/4". That is basically all I've ever asked for from my tools, and now I have it.
