- Feb 22, 2016
I searched and found a couple threads where smoke detectors were mentioned, but none that discussed the pros and cons of various types and features found on today's selection of detectors.
Right now we have First Alert Smoke/CO and plain Smoke detectors in the house, basement, garage, and shop. I had the first of them got TU last night. The five beep error code that translates to 'End of Life - REPLACE'. The manufacture date is May 2014, so it didn't make it to 10 years which they were supposed to last but at just under 8 years I guess not bad. This one lived in the hallway of the sleeping area of the house so not exposed to kitchen fumes or dust from the shop. SO I'm not sure what took it out but now I need to replace and thinking the other five were all purchased at the same time they are probably not far behind so might as well buy all new.
I'd like the new system to be the interconnected type and interface with SmartThings and/or Alexa which is what my First Alert devices do now, at least partially. I can't silence an alarm from SmartThings (ST) or by voice command to Alexa but I don't really care about that. I like that everyone in the house can get a notification on their phone if an alarm goes off or a battery is dead and that notification is identified by the name given to the detector in ST or Alexa. I'd like to have at least that much interoperability in the new system. I see new battery-operated wireless systems can interconnect and pass on alarms to all connected units when one alarms which I believe is required by code now.
So curious what others are using and what you like or dislike about the system you have. And if you dumped one system for another, problems with being deployed in a shop environment where the particulate level will be higher than normal, etc.
My shop takes up half of the 24x48 garage structure and is walled off from the garage area where the car is parked. I do not fully condition the shop space so the temperature swings from 40 in Winter to 85°F in the Summer. I keep the temp above 40 using a ceiling mounted electric heater controlled by a WiFi t-stat.
I have been looking at the First Alert ONELINK® TALKING COMBINATION SMOKE/CARBON MONOXIDE ALARM, Model SCO500 so if anyone has first hand knowledge of this alarm I'd like to hear about it.
I was looking at the X-Sense but I've read many negative reviews on Amazon about it so steering away from that brand.
Nest is another brand I was considering but I can not find anything that states it works with ST and I am too heavily invested in the ST ecosystem with over 80 devices to dump it. Most of those would probably work with another HA system so not a total loss if I did but still not looking to dump ST.
