Well, I pulled a real bonehead maneuver last night. I used my TS55 to gang-cut two sheets of plywood, so I ran the blade down quite a bit. Then, when I put it back onto my MFT/3, I forgot to put it back up. Yep, you guessed it, I cut completely through the top, even slicing into the side rail a bit.
So, the question is: How badly have I compromised the integrity of the MFT? Will it still hold square? Or should I replace the top?
Second question: What about the blade? I chopped into the side rail about 3/4". I think it's ok, but ...
