- Nov 14, 2013
Both items are new, but might be a little dusty. New retail value = $105. I'm looking for $80. You are welcome to pick them up if you are local.
[attachthumb=#]
[attachthumb=#]
From the website:
Non-Antistatic Hose, 27mm x 5m - 452879 - $85.00
The Festool Non-Antistatic Hose is designed as an economical option for use with non-antistatic dust extraction systems or vacuums. The 27mm Non-Antistatic Hose will fit or adapt to all Festool Dust Extractors and all Festool cleaning sets. A rotating connector prevents twisting and kinking, helping you work more efficiently. A tight-fitting reducing sleeve adapts for secure inside or outside fit to tool or cleaning accessory. Dimensions: 1-1/16 in x 16.5 ft (27 mm x 5 m).
Rotating connector prevents twisting and kinking, helping you work more efficiently
Tight-fitting reducing sleeve adapts for secure inside or outside fit to tool
Economical option for use with non-antistatic nozzles and extension tubes
Hose Sleeve, Rotating Connector for D 27 Non-antistatic Hose - 452891 - $20.00
Replacement Rotating Hose Connector for attaching Festool Non-Antistatic D 27 (27mm) hoses to the inlet of the CT 22 and CT 33 Dust Extractors. External diameter 58 mm. Use replacement rotating connectors and reducing sleeves to create new custom sized hoses from longer lengths, or use to replace damaged parts. Includes one Non-Antistatic Rotating Hose Connector.
For attaching Festool Non-Antistatic D 27 (27mm) hoses to the inlet of the CT 22 and CT 33 Dust Extractors
Use the Rotating Connector to replace a damaged end of your suction hose
[attachthumb=#]
[attachthumb=#]
From the website:
