- Jun 24, 2007
............... or not.
Decided to get he PB Swiss slotted screwdrivers in order have a set with parallel tips. Unfortunately I did not like them at all. Well that's not true I liked the handles , and the general quality, but the tips ....... not at all.
The theory is sound and I have one or two parallel tip drivers. But the PB Swiss do not seem to fit well in the screw recess. When using the correct size driver in the correct size screw I found it very difficult to keep it from slipping out or camming out. Even when going up a size to get a tighter fit they tended to slip out. Tried them in quite a few different screws. In fact my old Craftsman tapered and several other tapered drivers worked better.
I just don't think they fit the recess tight enough there was quite a bit of play. And the edges and corners of the tips are not crisp and square. The are more rounded and eased. They actually remind of a screwdriver that is worn out. I think this contributes to the slipping. I know that the corners are supposed to be "clipped" to fit the shape of a screw head and a countersink. But these are more rounded rather than cut at an angle.
I have one parallel tip Wera to compare. And it just looks like the tip is a better design. The Wera Parallel tips are discontinued but I managed to track them down and a set should be along in a couple weeks. Looking forward to trying them out. Hoping they will perform better.
Only one picture. I forgot to take a close up of the tips and they have already been returned.
