Just for fun I tried Drawboring the loose tenons. So far works great, but some comments:
When drilling holes they need to be perpendicular, I would recommend using a drill press.
When marking the tenon I found that running the bit in a power drill will give you a point and circle from the rad point bit. You can just drill between the center and the outside of the circle. (you could drill on the circle for larger pieces.
If using commercial dowels you really need a dowel plate as they tend to be very slightly over sized.
For 1/4 inch dowels in hardwoods you can sort of get by with out the drawbore pin. But you will likely have tear out and in softwood or brittle woods it is essential. (Two sources; Lie-Nielsen and Lee-Valley (under clamps ???). You may have bought some at a yard sale thinking that they were weird knitting needles ;D
Use the pins on both sides.
Drawbore one end of the tenon first then the other. I have had good success with 8 and 10mm. 6mm seems to work in some woods.
You can use the narrowest setting on the domino if you lubricate the tenon with a little beeswax mixed with mineral oil.
Eliminates faffing about with glue and worrying about open times!
I am building a test frame with construction grade pine (cheap junk) using 8mmx50 tenons and the narrowest setting without glue or drawbore and the other side with drawbore. I am going to load one shelf a the top with about 150lbs (68kg) and let it set on my deck for a couple of months and see how it holds up.
