jmbfestool
- Jan 9, 2009
A while ago I met a carpenter (not very good carpenter though) he had this large tool which once set up was amazing! It took a little bit of setting up but man it was quick! Bang mortice look done lift of door drop on next tighten and turn this handle and it would slowly move the tool up and down and in every time it had gone up and down until it reached the depth setting. bang another one done! I was impressed! I was going to buy one! unfortunately they are not so easy to get hold off! Also the price tag is £1000. Well the other day I came across something which is similar but smaller lighter and a lot less working out and fiddly parts also using a drill to operate!
I was wondering if any one has used one before it looks good and if I was going to do more than 3 doors on a job it would be a tool worth having as it doesnt look like it takes long to set-up. Unlike the big beast which takes a bit of time setting up I would want to be doing at least 10 doors even 15 to be bothered to get it out off the van you see.
http://www.axminster.co.uk/souber-dbb-mortice-lock-fitting-jig-(jig1)-prod830409/?src=froogle
JMB
JMB
