imaginarynumber
- Dec 18, 2009
Hi all
I recently replaced the brushes on my 150mm Rotex. Since doing so the speed seems to fluctuate, not massively but enough to worry me. I opened it up again and noticed that the commutator was very, very slightly dirty so I gave it a light clean with a bit of webrax. I then noticed that I hadn't pushed the connections on the brushes home as much as I should have.
Neither seems to have made any difference. Do the brushes take a while to bed in?
The other possibility that I can think of is that it might be relate to the plugIT connectors. Over the years the arcing has made one of the pins noticeably thinner than the other. When that first became apparent I wedged some copper strands in the plug to maintain a contact and "vowed" to never remove the lead... until I had to replace the brushes...
Whilst on site today, I did try to bend the thinner pin slightly and I was going to replace the PlugIT socket with the one on my faulty RTS400 but discovered that the flexes on the ends are different lengths.
Any advice will be gratefully received. Thanks
