LaserGecko
- Jan 26, 2007
Hi everyone,
I am currently not working as efficiently as I could with the trusty Festools. In fact, it seems like I'm chasing my tail quite a bit and working myself to death. My current project involves basically some big melamine cabinets. This is the first time I've been able to work with the material at MFT level since I found the perfect sawhorse at OrangeBorg. Previously, all my cutting was on the floor and I thought that was the reason for the extra workout.
I have two 1400 rails for slicing and dicing, the 48" Sommerfeld T-square, various other smaller squares, along with the semi-trusty Festool angle guide. There's nothing with ultra-high precision in my arsenal yet, but it is accurate enough to let me know when I'm off.
Today, I was taking the rough edges off in anticipation of making two 24"x72" pieces. I started with the short end, then the long edge and checked the alignment five or six times before I made the cut on each. Even though most people wouldn't, I went ahead and used the guide rail clamps just to be sure I didn't screw anything up. Well, as I was preparing the 72" chop, I discovered that the long edge wasn't perfectly square since the line was a bit askew. Sure enough, I checked the newly cut corner with my LED light and saw just enough light (and a tee-iny bit of wiggle) to make the whole damned thing significantly off at 6' out.
So, I recut it and did it perfectly.
It just seems that on any long cut, that it's so damned much work to get it just right. Am I missing something?
Would the best way to have done this would be to make a rough cut at about 73" to lop off the extra material, then make the final cut after the end was done?
How can I do this more efficiently?
Thanks!
Thanks!
