Corwin
- Jan 22, 2007
Sorry, but it may be some time before I can take new photos or a video. But, I am more than happy to help describe how it works further. It really is not that complicated at all. The jig uses Incra Tracks as scales that are mounted to the plywood base. Each Incra Track (the gold parts) has its own stop (in red). Set the two stops to the same setting on each scale and then place the jig on top of your material. Position the jig such that each stop is up tight against the edge of your material. The guide rail will now be parallel to that edge and you can cut your material. So, if you have set the two stops to 23-1/2", the piece you cut will be 23-1/2" wide.
My parallel jig is sized to cut down full sized sheet goods. Unlike the Festool parallel guides, the scales on my jig are set at a fixed distance apart -- I've made this jig 52" in length (along the guide rail). This size works for cutting down 5'x5' and 4'x8' material very well. I have a setup on two joined MFTs for making parallel cuts shorter than 52". You can easily make this jig a different size to suit your needs.
