I'm building a staircase using 2.5x12 stringers and 1.75x10 treads (pine). I'm buying the stock rough cut & oversized. The plan is to mortise the stringers to receive the whole tread cross section (1" deep). Stairs are "open" (no risers). One stringer will be against a wall, the other fully exposed to view. Ten treads. There is room (and enough muscle) to pre assemble the whole unit. I want to avoid showing signs of fasteners on the exposed stringer. I'm thinking pocket screws through the bottom of the treads into the stringers, with glue to minimize squeaking. Finish will be polyurathane.
I've built bunk bed ladders this way, but I don't know if this approach works for something much more massive. Any comments or suggestions will be appreciated.
Thanks,
Thanks,
