Dan,
Thank you for your question.
I'd like to remind everybody of the FAQ database on www.festoolusa.com (see link in the top left corner: "FAQ Database"). You can find
answers to your questions and ask questions there.
Here is what is in the database regarding the AS hose:
What makes an antistatic hose antistatic is that it conducts static electricity to ground. Festool antistatic hoses have no visible electric leads; the high-carbon plastic they are made from conducts high voltage. The tool is grounded by way of the hose, through dust extractor, to the ground where it is plugged. If there is an open ground where the dust extractor is plugged, there is still the possibility of electric shock from the high voltage static charge produced by moving dust.
Some dust extraction systems have a visible copper lead where you attach the hose. In that case, the conductive Festool antistatic hose will work to ground the tool to that dust extraction system. The ground must be continuous however for the system to work. The outlet it's plugged into must be grounded for the system to be antistatic.
Shop vacs are generally not antistatic. If you are using your Festool with a standard shop vac or another brand of dust extractor that is not antistatic then there is no need to purchase an antistatic hose, it won't eliminate static charge.
All thermal formable materials like plastics have ?memory?, they tend to retain their shape. Like your garden hose, unless you warm it, it will tend to coil in the same diameter that it came. If you warm your hose up by simply laying it in the sun, you can retrain it or straighten it out.
The conductive carbon used in the Festool antistatic hose is partly what makes it stiff. The non-antistatic hose is more flexible but not suggested for sanding due to the static charge generated by moving dust.
I hope that answers your question.
Regards,
Christian Oltzscher
Festool USA
