Ken Nagrod
- Jul 15, 2010
Tim,
I've been using 2p-10 for around 5 years and I never had a problem using it with crown molding. I usually just use their thick gel version. There are three types. I do get squeeze out, but I just spray it with the activator and carefully pick it off with my utility knife or the blade from it. I always keep a can of lacquer thinner around for cleaning the excess or removing glue from my fingers or fingers from wood. I have found that if you break the glued joint just after you've made it, spray the activator to cure it all and scrape off all the glue to the bare wood before starting over. Otherwise the joint won't hold with new glue over the old stuff.
I do like the improvements FastCap has made with the bottle top. I used to go through a lot of the old style tops because the red cap would glue itself to the spout and when I'd try to take the cap off, I'd take off part of the spout and then you have no way to seal the glue unless you carry spare bottle parts -- thank you Leanne!
