For those out there who enjoy a bit of DomiDogging
this is what i have been useing latley and i love em.
I have a few different sizes from 18 x 50mm (to plane or sand over) up to 50 x 50mm for heavy duty stuff.
Each Dog has 2 mortices on the bottom, the 2nd using the index pin. Then just glue in some Dominos. I lightly sand, then wax with some parafin to make them slide in and out easier.
Then plunge a mortice on each end useing the widest setting and raise for the second plunge for "fat" fingers" It makes it a breeze to lift out.
So if you have a few in the tool box or cupboard its a simple matter of a quick 2 plunges on your bench or sacraficial bench and you have an instant Super DomiDog to play with
As you see in the second pic, you can have 2 at each end and use wedges to secure some stock if you are going to route, sand or plane.
Have fun ;D
Have fun ;D
