Sys-AZ Pull Out Drawer Set
Flatsawn
Can someone tell me what the name of that "phillips" screw is that comes with the Sys-AZ Pull Out Drawer Set. What ever it is I don't have anything that fits it.
Thanks Mark
Thanks Rick,
More screw driver bit inventory. Great [mad] If they can't use a phillips, square is a good choice. Or even a torx, No we need to invent a better one. Which it probably isn't.  Rant over [big grin] Now I feel better.
Mark
Pozidrive is better. The Phillips head driver was originally designed to cam out of the screw so screws driven by machine into sheet metal wouldn't strip out the hole.
With a well formed Pozidrive screw and a good Pozi driver you can actually hold the driver with the screw (no magnets required). Way better than momentarily holding the Phillips screw with the Phillps driver.
Probably a European thing. We use Pozidrive more over here than Phillips. Buy a box of common or garden screw it will be Pozidrive 9.99 times out of 10!
