VW mick
- Apr 27, 2014
Thanks guys for nice comments. Hopefully some answers below
[member=1619]SRSemenza[/member] the roll around unit just ended up with those boxes in as I cleared up the sys5 has my hand tool insert in and the two above was the last 2 I needed a home for. I think it will end up with the ts and trion in as these are the tools I need too move out the cutting bench which is outside. With maybe a drawer at the top for some hand tools
[member=42735]DB10[/member] if I was to do this again (after the divorce) probably would have used an LR 32 system to make it a little more adjustable
[member=167]neilc[/member] I literally only used the QSWO as I had a load of off cuts. I only needed pieces about 400mm long so I was saving them from my job site for over a year
I drove every one mad about not putting any off cuts in the bins. If had to pay for it probably would have been ply
[member=45856]blaszcsj[/member]. Yes the rear drawer extension is to take the runners as they are 400mm the sys is only 300mm but I wanted to be able to open the lid when it was fully out
Plus the runners I got were 400mm. Below are a couple of photos of my bench. Although it was covered on a separate post some ware [attachimg=1][attachimg=2]
