woodferret
- Jan 5, 2020
Someone posted this on Facebook....
https://makerworld.com/en/models/93682#profileId-108331
It slides!
It slides!
woodferret said:Laid flat, it doesn't matter. Had this been printed vertically, then you'll get the layer lines that would interfere a bit with sliding. You can post-process ABS by sanding.
I print plenty of hose port adapters in ABS and none have sheared along the layer lines. PETG sometimes has if the walls are thin - but chonky PETG parts are very robust, more so than ABS.
If there's going to be a failure of this part, it'll be the ridge line that protrudes a bit to hold the systainer's groove. But there's an enlarged nub on there that if given enough walls, should hold unless one purposely pulls it out cantilevered like the injected part and then wails down on it more than even a metal slide would take.
If printed with a 0.8 nozzle, then it's really not going to go anywhere, since the interface between layers is approaching that of injection molding.
PaulMarcel said:At one time, I worked for a former best friend at his company that sold replacement parts online. The interesting chatter in the industry was how 3D-printed replacement parts could revolutionize the industry. Most of this was driven by super-fans making models for, say, piston heads for an older collectible car that were no longer available. Collectors could send these files to companies who could print it in metal with the proper hardening after-printing.
The gist of the concern in the replacement parts market was that big car manufacturers could make parts for recent production models for rapid shipment, but leave older models subject to remaining inventory or on-demand 3D printing/hardening. It is actually an interesting topic given that the drive and data came from aficionados not from the actual companies (surprise, I'm sure...)
Mainly one does not need dedicated tooling/jigs for long out of production parts, nor does one need to stock them as they can be made on-demand.RustE said:Additive Manufacturing removes some of the constraints around conventional manufacturing processes.
Packard said:Porsche is doing this in metals (pistons) and are using “additive manufacturing” instead of “3D printing”.
https://media.porsche.com/mediakit/porsche-innovationen/en/porsche-innovationen/3d-printed-pistons
Cheese said:Packard said:Porsche is doing this in metals (pistons) and are using “additive manufacturing” instead of “3D printing”.
Thanks for posting that Porsche link [member=74278]Packard[/member] ... [big grin] Very interesting, not unlike how powdered metal manufacturing substantially changed the automotive parts business.
It's interesting that Mahle, which has always supplied Porsche's pistons, is only doing the 2nd op's machining and not the 3D printing.
Packard said:Also, I’m not sure I understand what bionic engineering is.
