Before I begin let me just state that I bought the SYS-MFT from
www.powertool-supplies.co.uk (nuts & bolts) a few weeks ago
The T SYSTAND was provided free of charge by Rogier at
http://www.diafer.nl/
I've had the T systand for exactly a week now and had a good chance to try it out. First thing you will notice if you buy one is the craftsmanship, its very well put together. All edges are smooth and all joints are perfect. It looks very strong and I imagine it can take a lot of weight if needed. The rear foot that hooks to the next systainer is solid Beech and the front metal part that the T-loc knob connects to is what looks like laser cut stainless steel.
My T systand came with some spare stickers, a spare piece of beech moulding used to hook the rear to the systainer below and a spare metal part where the T-loc knob connects to. I dont know if these spare parts come with every T systand maybe Rogier can confirm this ??
I've decided the best way to compare it to the Festool SYS-MFT is to list all the various things i have noticed, some good things and some not so good.
SYS-MFT T SYSTAND
T-loc compatible & classic (but only on top) T loc ONLY (classic version available as far as I know)
Cannot clamp to sides easily Lots more clamping holes on sides
Fit to other systainers is exactly the same as any systainer (slight play) Fits absolutely perfectly with no movement whatsoever
The mdf top doesn't fully cover the systainer (there is some plastic) The birch ply top is ply all the way
Very light Heavier as its 18mm plywood
Internal storage No internal storage
Rubber grip strip on top & V groove V groove only
Can stack anywhere in a stack of systainers Can only go on top of a stack
Build quality the usual quality you would expect with festool Excellent build quality, you can tell Rogier wants to supply a quality piece of kit.
Its been a pleasure to review both these portable bench's and I hope the info helps others in their decision on which one to buy, or you could buy both [big grin]
Here's a few more photos for you.
