Leifer said:That is good to know.
I'll stand corrected, for now.
I was contemplating a theory like this:
If attaching several right-angle chucks to each other in a row (several bends), would the torque be reduced at the bit ?
It seems it would, for the several gear bends. If it does "for several", than it would be there for one.
But not likely noticeable with one gear bend (right-angle chuck) (and the eccentric chuck with two bends ??).
I forgot to take engineering or "gear theory" in college, so I am not sure of my idea.
I do hope I am mistaken, but it did cross my mind.
Thanks.
Edit: I have some very good "dial torque wrenches" up to 100 Nm. When I get my C18 set, I'll connect the eccentric to the right-angle chucks, and test them at a readable drill clutch setting.
I don't know what real life application you attempting to do, but you can' mount to right angle chucks to each other if that is what you are looking to do.
"The output power is the (input power - the power losses). Power losses in gear systems are associated primarily with tooth friction and lubrication churning losses. Churning losses are relatively independent of the nature of the gears and the gear ratios - they are primarily related to the peripheral speed of the gears passing through the fluid. Churning losses are difficult to calculate and estimates based on experience are often used in initial gear design. The frictional losses are related to the gear design,the reduction ratio,the pressure angle, gear size, and the coefficient of friction."
LINK
Leifer said:It's easy to forget that any connected gears are always plowing through lubricant, as are the bearings.
Bohdan said:Leifer said:It's easy to forget that any connected gears are always plowing through lubricant, as are the bearings.
Only in an oil filled gearbox. Drill gears are usually greased and the excess grease is forced out of the gear teeth after the first rotation so it contributes little to the plowing effect. Same with ball bearings but I would suspect that these are bushes.
The net result is that the effect is very small and you probably wont be able to detect or measure it as a change in torque.
Bohdan said:Only in an oil filled gearbox. Drill gears are usually greased and the excess grease is forced out of the gear teeth after the first rotation so it contributes little to the plowing effect. Same with ball bearings but I would suspect that these are bushes.
