Mario Turcot
- Nov 26, 2017
[member=57948]ChuckM[/member] What kind of pressure in lbs the Jessem's hold down apply?
I'm considering them on my Hybrid table saw.
Mario,Mario Turcot said:[member=57948]ChuckM[/member] What kind of pressure in lbs the Jessem's hold down apply?
Dick Mahany said:For thin rips and face frames, using a simple feather board and push stick in addition to the riving knife or blade guard has been very beneficial in maintaining parallelism over the entire length of the cut. It does take a few seconds to reset the board if the stock width varies, but the results are worth it every time.
Also, an auxiliary tall fence can help with one or more featherboards although they can restrict push stick usage for very narrow rips.
[attachimg=2]
Mario Turcot said:snip.
ChuckM said:The guides can be used as a stop bock when cross cutting as shown in the attached image. No need to clamp a block to your fence.
Brian Livingstone said:Hi Mario,
What is on top of the box ? Featherboard ?
I have the guides on my LaGuna Fusion. Really like them.
Brian
Mario Turcot said:Snip.
Took 10 minutes to install![]()
rvieceli said:[member=66597]Mario Turcot[/member] which model Mag-switches are those?
Ron
