Template for dovetail joints for beams
zoki4691
The template for dovetail joints for the beams.
I love carpentry work and if I can reproduce this template (original and aluminum) I will be very happy.
Of course, I wanted to do measurements x my needs. Make a template  for interlocking for joists, then the measures contained.
I already have right milling, I have the cutter with driving bearing, it just lacks the dima.
Construction material and birch phenolic plywood plywood
View attachment 1[attachimg=2][attachimg=3]
[attachimg=4][attachimg=5][attachimg=6][attachimg=7][attachimg=8][attachimg=9][attachimg=10][attachimg=11][attachimg=12][attachimg=13][attachimg=14][attachimg=15][attachimg=16]
More photos...[attachimg=1][attachimg=2][attachimg=3][attachimg=4][attachimg=5][attachimg=6][attachimg=7][attachimg=8][attachimg=9][attachimg=10][attachimg=11][attachimg=12]
[member=25893]zoki4691[/member] did you make this pattern or buy it? I am interested in one as well.
If you're interested, I'm going to sell it? I did some paterns
Id be interested in purchasing a set for a pergola build in the spring.
Gregor said:
Nice.
Pocess Is Biesse Rover 325 [smile]
Will you share the process of making the templates?
Will have to pass on that as I don't have enough space in my shop  [sad]
That is a monster bit (#492667). I searched but does not appear to be available in NA. I see the shaft is 12mm. Is a 12mm collet available for the OF1400, I didn't see one in the current Festool catalog.
The 12mm collet for OF 1400/2200 is #494462 (Spannzange SZ-D 12,0/OF 1400/2000/2200).
Let me know if you are going to sell the templates.  I am interested.  Please let me know where to find this information.
I want to make a set to or buy a set. Please contract me asap. I will buy a set or buy the plans to have a set made locally.  Please.
Sent from my SM-G928W8 using Tapatalk
Very nice job!
As i have to build a pergola for a friend, i would be very interested in buying the templates!
What is the reference for the first bit you use (with a 15° angle)?
zoki4691 said:
Gregor said:
Nice.
it’s nice. Plans or template would be nice. I could see myself nicking and ruining the template with the large bits. With plans I could just rout out a another one if I break the template. I don’t have an immediate use for it but things change.
Any updates on making custom templates.  Looking for a template for 2x10s to dovetail on beams for a covered pergola build.
Looks like it's been a year since he was last on here.
