Template for shelves in "Festool rack" for van
KimEirikUri
Hello everyone. Im a kitchenfitter from Norway, and I am about to make a rack in my new Van, a Transporter T5.
I have googled and browsed this forum for good ideas, and I found something that caught my eye.
Is there any kind of template available for these shelves?
Thanks.
I just made my own out of 12.5mm ply, cut out the holes for the feet with a jigsaw then used the template with a router to cut the shelves
Ok. I guess I have to try making my own template then :)
richy3333 said:
I'd be interested too. Picked up my long wheelbase T5 highline today. Sw-eeeet!
I picked up mine today aswell..
The picture you posted of Wing79s buildout I believe was done with a cnc router. I copied his shelf design in my van. I made a template out of 1/2 plywood and then routed out all the shelves with a template bit.
Must be that time of year for dealers making their numbers.
Great ride.  I prefer those alloys to the ones I got. They were on my last T5
They're called " Tangis" I've been looking for a cheap second-hand set for my t5.
Oh.. I don't have a CNC Router :)
Is it possible to use a normal router? I own a Bosch router, but I have never used it. Can it do the job with the right kind of "cuttingsteel"? Would be nice if someone know about a guide how to use it for things like this.
I made my shelves with the festool 1400. It can absolutely be done! Does your bosch router plunge?
Heres a picture of what I have done so far.
Nice.
Yes, I think it can. Like I said.. I have never used it before. I bought it for a stair project, but I ended up buying stairs from a factory instead :) Did you make some guidinglines out of wood, or what?
I'm learning how to use Sketchup Pro's Layout feature to create dimensioned plans, and since one of my next projects is a SYS/MFT cart/table I thought I would practice with the systainer bottom.
[attachthumb=1]
The systainer model was downloaded from the Trimble 3D warehouse, credit to [member=1146]Brice Burrell[/member] - I just imported it into Sketchup then created a Layout drawing with dimensions. Brice noted on the model it is 95% accurate, so no warranty given that these dimensions actually match the systainer, but I suspect they do.
RMW
Scaled Plan Attached:
[attachthumb=2]
As a sidebar - Brice did so much for us here.  I know that his sharing of knowledge helped me a ton.  I wish he was more active.  i hope that he is extremely busy with work!
Hi there,
I too was inspired by wing79.
I copied his "four feet" shelving system. It works well.
The systainers lock in and they don't fall out even in windy roads.
To make them I simply placed a systainer on a pre sized pc of shelving. (16"x12")
First centered it then I used and engineers square to mark out feet location on shelf.
Then I connected my lines with a framing square. I drilled a through hole in each square and cut them out with a jig saw. Then I just clamped this jig on top of my shelf blanks and plunge routed each indent. I used a short top bearing 3/4 template bit. It took less than s minute per shelf. I think went to a depth of about 8 mms. I left the round corners on the indents DNS the systainers drop in perfectly with s nice "positive stop" feel.
I then cut out the front indent out of my template with a jigsaw. Again I clamped this on top of each blank and routed each front with a large top bearing template bit. Again each cut took only a minute. Thsnks for the inspiration fellow foggers!
I'll post more pics when complete.
I will help anyone who wants my input. I blasted what I have so far in two nights after work.
The plan is to finish the truck to be uber nice and uber fuctional. I can't wait to rifle on it again!!
Thank you all so much for the great feedback.
This is the router I have, a Bosch POF 1400 ACE:
And I would need a router bit like this to make the plunging for the drop in: http://www.woodcraft.com/product/845409/freud-50116-pattern-router-bit-top-bearing-34d-1cl-12sh.aspx
Is that correct?
Great setup btw :)
Just thinking out loud...if you cut these with a router you get rounded corners. That's ok because the feet don't need to hold as a perfect fit they just need to locate in order to prevent sliding forward or jumping out. Therefore a properly sized and positioned round hole would suffice. Perhaps a full cut out using a hole cutter or a partial depth using a forstner type bit?
The template would be real easy. [blink] [popcorn]
Yes a bit like that but with a shorter cutter. The one pictured has a 1" tall cutting surface.
With thus bit you would need a thicker template for the beating to track. Get the same but but with a shorter cutting height
I found the square cut, to the exact size as the "sys feet", with a 3/4" radius cutter, locked the systsiner with little or no "slop". I hate when things rattle around while I'm driving. Getting everything do that it is quiet under normal paved driving conditions is really important to me.
