Why "penultimate"? As I searched the previous FOG postings I found that "ultimate" seems to be taken for most any situation one could imagine. I also want to leave room for inevitable improvements to be made by others.
I was just recently able to find a second MFT 1080 which works great in my shop. While trying to adapt the great single MFT setup work done by Steve Adams and Paul Marcel and others to work with two MFTs that I showed in two earlier posts, I made an accidental discovery that only works on the MFT 1080. If this is already known, I apologize in advance but I couldn't find any reference to it on the FOG. I had both 40 series and 60 series aluminum extrusions for testing and almost by accident set the 40 series on the MFT top rail. I noticed that the The slots almost perfectly lined up. It turns out that it is the almost that makes all the difference.
[attachthumb=#]
Here you can see, if you look very closely, that the lip of the extrusion closest to the table top just extends over the edge of the MFT slot.
[attachthumb=#]
When a fastener is tightened, the extrusion is pushed tightly against the the edge of the top which is just as precisely and squarely cut as are the holes.
The closest analogy I can think of is like drawboring a peg to tighten a tenon, back before the domino that is. The point is that the extrusion is now referenced to the edge of the top and not to the table rails which are most usually not square to the top.
The process of putting this together involved drilling some holes in the extrusion. I initially intended to fasten only to the MFT that held the guide rail but later found that the implications of this application went much further.
[attachthumb=#][attachthumb=#][attachthumb=#]
Here I show the holes and fasteners I used.
The tricky part is lining the fasteners with the holes in the extrusion.
[attachthumb=#][attachthumb=#][attachthumb=#][attachthumb=#][attachthumb=#]
Sliding them on one at a time and securing them each with a screwdriver as I went worked for me.
[attachthumb=#]
Because the edge is as parallel/perpendicular as are the holes, this results in a fence as square to the rail as I can measure.
My remaining problem was that I couldn't find a commercial flip stop to work with that setup. A metalworking friend replaced the too long arm on this Rockler flip stop with this and I additionally have a threaded hole to make a micro adjuster.
Now, at least for me, it really gets interesting. Since as I said, I had just gotten my second 1080 I drilled more holes in the extrusion and connected it also. I also added a second extrusion on the other side of the MFTs and pulled them together with a few clamps underneath. I got out my dogs and started checking the result.
I found that the second table was also square with both fences and that a floating bar crossing both tables was square to the rail anywhere it was placed. To me it seems that the tables are not merely connected, they are joined. This leaves me with the largest cutting area I think I can get from two tables. I think this will also be very useful as an assembly table for squaring up parts.
A final use for the bars on opposite sides of the table is shown below.
[attachthumb=#]
Here you see the chop saw I use while waiting for it to die so I can drink more Festool cool-aid. I often want to make additional use of the MFT surface but don't like to leave something this heavy sitting on the MDF for very long. Now I don't have to. It is just sitting unsecured in this photo but I now have a number of more permanent jigs planned.
I know most of you have moved on to the MFT/3 but I hope there are still some of you who will find this interesting.
Dick
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
Dick
