I was thinking that if someone could come up with an after-market set of cutters for DF700 to be used as a DF500 (that actually did extend the domain of the DF700), may be something could be done to benefit the DF500 users.
I mentioned about using only the standard setting with a longer cutter. Why deeper? To add strength to a joint, for the same reason why Festool has the 8 x 22 x 80 mm & 100 mm Dominos.
In a recent project, with the DF 500, I cut my mortises to the max. (57 or 58mm?) and then cut a batch of 80mm Dominos to an hair shorter than 58mm. I then drilled a deep hole into each mortise for the excess glue. Did 8mm longer matter? I don't know but that was all I could do -- unless I borrow a DF700 from a buddy (that would have quite delayed my project).
I knew owning a pair of the DF500 & 700 would be the best option, but I would not use the DF700 enough to justify it, as a hobbyist. Between the two, I would prefer to have DF500 for its ease of handling.
The making of custom Dominos is my least concern even if I don't want to modify Festool stock (probably the 80mm or 100mm ones). I can cut floating tenons of any size and length with ease in my shop.
May be someone could study this in depth and explore if it is technically feasible to extend the capability of the DF 500 a bit. Yes, on the surface, it is un-doable, just like many other inventions -- the SawStop is an example until it came to the market.
Chuck
