Darren1972
- Jul 23, 2015
can i use my 18 v 5.2 ah batteries in a ti15 impact driver thanks
jbasen said:I posted a suggestion to the Festool Wish List a while back asking for the ability to use a higher voltage battery than a tool is rated for. Festool would need to include circuitry in a battery so it would detect the voltage the tool would expect and reduce the battery voltage. The tool wouldn't get any more power but the battery could provide a longer run time.
Since I own a T18, not being able to reuse my batteries kept me from purchasing a TI 15
jmbfestool said:jbasen said:I posted a suggestion to the Festool Wish List a while back asking for the ability to use a higher voltage battery than a tool is rated for. Festool would need to include circuitry in a battery so it would detect the voltage the tool would expect and reduce the battery voltage. The tool wouldn't get any more power but the battery could provide a longer run time.
Or don't bother with the 14.4v tools. I don't see any point in why festool still make 14.4 tools.
They started with the 14.4 and then started making 18v which can accept down to 10v 12v and 14.4v
Now that their higher VOLT tools accept lower volt batteries why even bother making and selling 14.4 tools.
Great example is the T15 and T18 why would any one now even buy the T15??? Size weight is identical only slight differences are power and cost. I personally think festool should stop making the T15 it's become obsolete.
If people want 14.4 volts or 18v then the batteries are just different but the tool is the same.
So if you want a T15 you actually get a T18 with T15 batteries.
That would be a lot easier than redesigning batteries to reduce voltage output.
jbasen said:jmbfestool said:jbasen said:I posted a suggestion to the Festool Wish List a while back asking for the ability to use a higher voltage battery than a tool is rated for. Festool would need to include circuitry in a battery so it would detect the voltage the tool would expect and reduce the battery voltage. The tool wouldn't get any more power but the battery could provide a longer run time.
As a T18 owner it was all about using 18v batteries in a TI 15 since Festool didn't make a 18v impact tool. There are a lot of people out there with older drills and it would also allow them to invest in the larger batteries and still leverage their investment in their existing tools.
I agree with you that I don't see a reason to purchase a 14.4 v drill today.
